Api session event editor weather set attribute
API Endpoint: api/session/event/editorweather/set_attribute/
Description: Set Weather numeric Attribute value
| 0 | REQUIRED | (WEATHER Integer ID or multiple integer values in array [1, 2, 3]) | Weathers | |
| 1 | REQUIRED | (String) | Attribute Name | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Numeric Attribute Values | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorweather/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST
fetch("https://engine.tygron.com/api/session/event/editorweather/set_attribute/", options)
