Api session event editor functionoverride remove attribute
API Endpoint: api/session/event/editorfunctionoverride/remove_attribute/
Description: Remove an Attribute from a Function
| 0 | REQUIRED | (FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) | Functions | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attributes |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute 1", "Attribute 2", "Attribute 3" ] ]'JavaScript example POST
body: '[ 1, "Attribute 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_attribute/", options)
