How to change multiple Attributes at once for Water Overlays
How to change multiple Attributes at once for Water Overlays:
  1. In the Water Overlay Wizard, go to the step where you want to change multiple values for an Attribute.
  2. Check the Multi checkbox and click on the Set Values button for the desired attribute.
  3. In the new panel that pops up, click on Import new CSVs in the bottom right corner and select the CSV file.
  4. Optionally, change the delimiter and click on Ok. The data in the CSV file is now used to set the new values for the attribute.
Water Area, Water Area 2
-1,-2
The first row should contain the exact names of the hydrological features or hydraulic structures whose attribute values you wish to change. The second row contains the new values for this attribute.
  • For the CSV, it is possible to choose a comma or semicolon as delimiter.
