Geo Option
Revision as of 10:19, 12 November 2026 by Frank@tygron.nl (talk | contribs)
Geo Option in relation to Sources and Geo Plugins
Geo Options are items that store particular settings used by the Tygron Engine when generating a new project.
New Project Wizard
While selecting new Project's area, advanced options can be accessed.
When choosing the location of the project area during the New Project Wizard, in the second panel of the wizard, the default mode for data selection is Selection. When checked, the Tygron Engine acquires various open datasets linked to the selected area. Find an overview on which data is used to create a new 3D model on the Project Source page. The Advanced Options panel can be found above the selection option. Opening this panel displays several available open datasets. You can choose to include or exclude specific data sources during project creation.
List of Geo Options
Name Default Value Type Description
AGRICULTURE true Boolean Agriculture (crop fields, grassland, etc)
BAG3D_GEOMETRIES false Boolean Use 3D BAG by tudelft3d for Building Geometries
DTM_DSM_THRESHOLDS 0.0 0.0 0.0 double[] Apply DSM to DTM Thresholds for Land, Roads and Other.
HEIGHTMAP_RESOLUTION NORMAL HeightmapOption DEM Resolution
I3S_GEOMETRIES false Boolean Use I3S Scenelayer for Building Geometries
IMWA true Boolean IMWA Water System constructions such as culverts
INTEREST_AREA_MARGIN 500 Double Default margin around Area of Interest on file drop
NL_AHN AHN4 AHN Dutch AHN elevation model version
NL_BGT true Boolean BGT (provides more detail for roads, water, street objects, and trees)
NL_ENERGY_LABEL true Boolean Address Energy Labels
NL_MAX_TREE_HEIGHT 50 Double Tree Height from AHN Surface (max value in meters)
NL_MIN_TREE_HEIGHT 5 Double Tree Height from AHN Surface (min value in meters)
NL_TRAFFIC_INFOMIL true Boolean InfoMil Ruleset
NL_TRAFFIC_INWEVA true Boolean INWEVA 24h Traffic Data
NL_TRAFFIC_NSL true Boolean NSL Monitoring
NL_TRAFFIC_NSL_CONVERSION 0.051 Double NSL Conversion from day to hour values (default 1.22 / 24)
OSM_BUILDINGS true Boolean Use OpenStreetMap for Buildings
OSM_LANDUSE true Boolean Use OpenStreetMap for Landuse
OSM_NEIGHBORHOODS true Boolean Use OpenStreetMap for Neighborhoods
OSM_ROADS true Boolean Use OpenStreetMap for Roads
OWNERSHIP true Boolean Ownership (cadastral data)
RISK_ASSESSMENT false Boolean Risk Assessment (detect e.g. dangerous objects like LPG stations)
SATELLITE_RESOLUTION HIGH SatOption Satellite background imagery resolution
TREES DEFAULT Trees Tree options (DEFAULT, NONE or AI generated)
UNDERGROUND true Boolean Underground (soil type)
WATER true Boolean Water (rivers, canals, etc)
WORLD_WATER OSM WorldWaterOption World water Source (rivers, canals, etc)
ZONING false Boolean Zoning plan (limitations to Buildings)
WorldWaterOption
Name Description
OSM OpenStreetMap
TOPO Topographic Map
NONE None
SatOption
Name Pixel size
SUPER 0.1
HIGH 0.25
NORMAL 0.5
LOW 2.0
AHN
Name Publication Year Description
AHN3 2018 AHN3
AHN4 2022 AHN4
AHN5 2024 AHN5 (South West only)
AHN6 2025 AHN6 (Incomplete)
HeightmapOption
Name
HYPER
SUPER
HIGH
NORMAL
LOW
BASIC
Editor
Editor → Tools (Ribbon tab) → Template (Ribbon bar)
Use the template settings screen to define the default data sources for the template. For example, selecting AHN3 ensures it is always used for projects based on that template. Changes made are stored in Geo Option items.
