Api session event editor geooption set string
API Endpoint: api/session/event/editorgeooption/set_string/
Description: Set the value of a Geo Option to a text value
| 0 | REQUIRED | (Enumeration) | Geo Option Type | AGRICULTURE, BAG3D_GEOMETRIES, DTM_DSM_THRESHOLDS, HEIGHTMAP_RESOLUTION, I3S_GEOMETRIES, IMWA, INTEREST_AREA_MARGIN, NL_AHN, NL_BGT, NL_ENERGY_LABEL, NL_MAX_TREE_HEIGHT, NL_MIN_TREE_HEIGHT, NL_TRAFFIC_INFOMIL, NL_TRAFFIC_INWEVA, NL_TRAFFIC_NSL, NL_TRAFFIC_NSL_CONVERSION, OSM_BUILDINGS, OSM_LANDUSE, OSM_NEIGHBORHOODS, OSM_ROADS, OWNERSHIP, SATELLITE_RESOLUTION, TREES, UNDERGROUND, WATER or WORLD_WATER |
| 1 | REQUIRED | (String) | Text Value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeooption/set_string/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", "Text Value" ]'JavaScript example POST
body: '[ "NL_BGT", "Text Value" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeooption/set_string/", options)
