Setting
Setting is an item that stores configuration properties of your project.
List of available settings
| Name | Default Value | Description | |||
| ACTIVE_SCENARIO | 0 | Currently active Scenario | |||
| AI_EDITING | true | When true AI Agents are allowed to edit project data. | |||
| AREA_GROUPS | Group Areas based on these Attribute names in Tygron Client | ||||
| AUTO_CALCULATION | false | If true, Indicators, Panels, and Overlays are automatically recalculated on data changes | |||
| BASE_PANELS | HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL | Basic Panels set (that are not Triggered by special Functionality) | |||
| CURRENCY | EURO | Project currency | |||
| DECIMALS | 6 | Decimal accuracy used in Attributes and Function Values | |||
| DEFAULT_GEOPLUGINS | Default Geo Plugins in new Project Wizard. Stored as pairs of Maplink and Geo Plugin ID, separated by spaces. | ||||
| DEFAULT_GROUND_LOWER_PRICE_M3 | 50 | Default price for lowering 1 m3 of ground | |||
| DEFAULT_GROUND_RAISE_PRICE_M3 | 50 | Default price for raising 1 m3 of ground | |||
| DEFAULT_GROUNDPRICE_M2 | 400 | Default price per square meter of ground | |||
| DETAILED | true | High resolution project | |||
| EXPORT_CRS | EPSG:3857 | Default export CRS for Polygon data in Tygron Client | |||
| GRID_CELL_SIZE_M | 2 | Overlay grid cell size in meters | |||
| IMPORT_CRS | Default import CRS for Polygon data in Tygron Client | ||||
| IMPORT_CRS_FORCE_XY | true | Default import CRS (force XY) for Polygon data in Tygron Client | |||
| ITERATIONS | 1 | Amount of Iterations during a recalculation update. Min Value: 1 and Max Value: 1000 | |||
| KEEP_ALIVE | NEVER | Keep Project alive (active) base on this Setting | |||
| LIMIT_MAP | MULTIPOLYGON EMPTY | Limits Project map generation and later calculation to this MultiPolygon | |||
| MAP_SIZE_M | 0 0 | Project map size in X (longitude) and Y (latitude) in meters | |||
| MAX_TOTAL_GRIDCELLS | 0 | Maximum amount of Overlay grid cells per Project | |||
| MEASUREMENT_SYSTEM_TYPE | SI | Unit system for Measurements | |||
| MIN_CELL_M | 0 | Minimum Overlay grid cell size in meters | |||
| MODEL_STYLE | TEXTURED | Model (Buildings, bridges, trees, etc.) style used for visualization in Tygron Client | |||
| PROJECT_NAME | Project Name | Project name | |||
| RASTERIZATION | COMBINED | Selected rasterization method to convert Polygon into the Overlay Grid raster | |||
| RECALCULATION_REQUIRED | false | If true, a manual recalculation update is required | |||
| RECENT_CRSS | EPSG:3857 EPSG:4326 | Recently used export CRS values in Tygron Client | |||
| REGION | NORTHWESTERN_EUROPE | Project Region: used to define the default Functions | |||
| RESERVED_LAND | MULTIPOLYGON EMPTY | MultiPolygon for reserved land used in sale transactions | |||
| SATELLITE_BRIGHTNESS | -1 | Compensates for dark satellite backgrounds in Tygron Client visualization | |||
| SATELLITE_COLOR | RGBA color to use instead of Satellite imagery for visualization in Tygron Client | ||||
| SATELLITE_FILE_NAME | default | Name of the satellite background asset files | |||
| SCHEDULED_UPDATE | Scheduled update Timestamp in milliseconds | ||||
| SCHEDULED_UPDATE_MAIL | Email Address to notify when the Scheduled Update has finished | ||||
| SCHEDULED_UPDATE_SMS | Phone number to notify via SMS when the Scheduled Update has finished | ||||
| SECTOR_SIZE_M | 500 | Height sector tile size in meters | |||
| SHOW_ACTION_LOG | true | Show Action Log Panel in Tygron Client | |||
| SHOW_BUILDING_AND_MEASURE_POPUP | false | Show interaction Popup when a Building is placed | |||
| SHOW_WATER_POPUP | false | Show interaction Popup for the water authority when a waterway is placed | |||
| SKY_TYPE | DEFAULT | Sky visualization type in Tygron Client | |||
| SOLAR_PANEL_POSITION | 0.0 -0.5 -1.0 | Solar Panel positioning used for visualisation in Tygron Client|- | STATE | NOTHING | Simulation Timestate |
| SUN_DATES | Project sun dates used for Sun visualisation in Tygron Client | ||||
| SUPER_USER_MESSAGE | Super user message to all clients | ||||
| SUPPORT | PREMIUM | License support level | |||
| SURROUNDING_MAP_EXTEND_M | 0 0 | Surrounding map extent for visualization of Satellite and Elevation around the Project map | |||
| TIME_ZONE | Project TimeZone offset | ||||
| TIMESTAMP_FORMAT | dd/MM HH:mm:ss | Timestamp Format for importing and exporting date/Time values, such as in CSV files | |||
| TQL_TOKEN | true | When true allow TQL Queries to access the API token. | |||
| TRAFFIC_VISUAL_MULTIPLIER | 4.0 | Traffic visualisation multiplier in Tygron Client (not used in calculations) | |||
| WATER_HEIGHT | -20000.0 | Average water elevation reference Point used for visualisation in Tygron Client | |||
| WATER_TYPE | CANAL | Water visualisation type in Tygron Client | |||
| WEB_ALLOW_LOGIC_EVENT | true | Allow logic Endpoint execution for Web Viewers | |||
| WEB_ALLOW_PARTICIPANT_EVENT | true | Allow participant Endpoint execution for Web Viewers | |||
| WEB_ALLOW_QUERIES | false | ||||
| WEB_BASE_MAP | SATELLITE | Background type used in Web Viewers | |||
| WEB_DEFAULT_APP | 2d | Default Web Viewer type (2D or 3D) | |||
| WEB_FRONT_PANEL | -1 | Open Web Viewers with this Panel ID instead of default map | |||
| WEB_MAP_CUSTOM_PANEL | -1 | Panel ID used to retrieve and replace custom content for the 2D and 3D Viewers | |||
| WEB_MODEL_SHADOW | true | 3D Web Viewer shadow visualisation enabled | |||
| WEB_MODEL_SPACING | 2.0 | 3D Web Viewer model spacing, distance between e.g. trees | |||
| WEB_MODEL_STYLE | WHITE | Web Viewer Model style (COLORED or WHITE) | |||
| WEB_MODEL_TEXTURE | MEDIUM | 3D Web Viewer Texture quality/size (SMALL, MEDIUM, LARGE) | |||
| WIND_DIRECTION | 135 | Wind direction angle in degrees | |||
| WIND_SPEED_M_PER_S | 5.0 | Wind speed in meters per second | |||
| WIZARD_TIME_MINUTES | -1 | Project map generation Time in minutes | |||
| WORLD_REFERENCE_POINT | 0 0 | World reference Point (upper left corner) used to convert local coordinates to EPSG 3857 world coordinates |
API Endpoints
