Cinematic
Revision as of 14:36, 22 September 2026 by Frank@tygron.nl (talk | contribs)
Cinematic Datas in relation to Special Effects and Environmental effects
In the Tygron Platform, a cinematic is an automated movement of the viewport-camera in the 3D Visualization along predefined Key Points. While watching a cinematic, a Stakeholder is unable to take any actions. When the cinematic ends, the Cinematic camera switches to the last selected camera mode, directing its view based on the last Key Point.
A Cinematic can display text to a Stakeholder when necessary. This can happen in two ways. The text can be displayed as a subtitle, while the camera continues to move in the cinematic. Alternatively, displaying the text can pause the cinematic, until the user confirms they wish to continue.
Finally, Event Bundles can also be fired at Key Point which can affect the 3D Visualization, such as:
When to use cinematics
Cinematics are generally used for exposition to the user. When it is necessary to provide information to a user, or to direct their attention to a specific predefined location in the 3D Visualization, this can be done using a cinematic. Because a cinematic takes away the user's ability to move the camera themselves, and to take actions, a cinematic is best used for vital information which only has to be provided once. An example of this is an introduction to the area at the start of a Planning Session.
By default, a welcome cinematic is present in each project, automatically generated when the project is created. This cinematic is displayed to all stakeholders at the start of the planning session, and is a brief introduction of the zones present in the 3D Visualization.
Creating and editing cinematics
Editor → Tools (Ribbon tab) → Cinematics (Ribbon bar)
In the editor, it is possible to create, duplicate, edit and delete cinematics in a project. It is also possible to create Key Points, or remove Key Points from a cinematic. In the following how to's these functions are explained.
