Ownership Overlay
Revision as of 14:19, 22 September 2026 by Frank@tygron.nl (talk | contribs)
Example of the Ownership overlay
The Ownership overlay is available by default. This overlay displays the ownership of properties across the entire project area, using a separate color for each stakeholder. This overlay is important when considering which stakeholder may perform actions such as constructing or demolishing at a given location, or whom to negotiate with for Buy land. Stakeholders are defined by the different parties who own land in the project area.
Since ownership data is not available as Open data, the overlay is made up by combining different Open data-sets:
  • BRK- Kadastrale kaart; for knowing the parcel borders in the project area
  • BAG; to know the function and size of buildings, for example to know if a building is a house, School or a Company
  • Risicokaart; also for knowing functions of buildings
  • BRP Gewaspercelen; to know what is Agricultural land
  • BGT and TOP10NL; for knowing the Topography of the project area
These datasets combined provide an estimation of who the owners of the land could be.
Generally, the Municipality owns roads and public green space. Agricultural land is typically owned by farmers.
To know if a building is owned by a housing corporation, if it is private property or if it is owned by another Stakeholder, the Tygron Platform first matches the building to the other data-sets to know which type of building it is. For example, if is known from Risicokaart that the building is a School, the Stakeholder will be Education. If the data matching does not provide a Stakeholder, an estimation is made based on the size of the units and the building. Generally a building with multiple smaller houses, will be of a housing corporation. A building with one or more larger houses will be private property.
Since this overlay is an estimation, we advise to import own ownership data if that is available to you.
Hover panel displays additional information
When clicking on a specific location in the map, the hover panel gives additional information about the type of function, the height and the owner of the land.
  • The Ownership overlay is added by default when creating a new project.
API Endpoints
