Network Distance Overlay
Revision as of 14:12, 22 September 2026 by Frank@tygron.nl (talk | contribs)
The Network Distance Overlay showing how much distance there is between Buildings and underground Net lines.
The Network Distance Overlay is a Grid Overlay which displays the distance (if any) between underground Net lines and Buildings which extend into the underground.
For each Grid cell, the depth of the Net line is compared to the presence of underground Buildings. If a conflict is possible in a specific cell, the computed value for that cell is the smallest distance between any Net line and any Building.
Distance calculation
Net lines are checked for distance against both Buildings above ground and Buildings below ground. This is done based on the Function Values the Building has. The following details determine the extent of the Building in the underground for testing distance:
If the Net line's height passes through the extent of the Building, the computed distance is 0. Otherwise, the distance between either the top or the bottom of the Building is used.
API Endpoints
