Setting
Revision as of 09:25, 21 September 2026 by Frank@tygron.nl (talk | contribs)
Setting is an item that stores configuration properties of your project.
List of available settings
Name Default Value Description
ACTIVE_SCENARIO 0 Currently active Scenario
AREA_GROUPS Group Areas based on these Attribute names in Tygron Client
AUTO_CALCULATION false If true, Indicators, Panels, and Overlays are automatically recalculated on data changes
BASE_PANELS HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL Basic Panels set (that are not Triggered by special Functionality)
CURRENCY EURO Project currency
DECIMALS 6 Decimal accuracy used in Attributes and Function Values
DEFAULT_GEOPLUGINS Default Geo Plugins in new Project Wizard. Stored as pairs of Maplink and Geo Plugin ID, separated by spaces.
DEFAULT_GROUND_LOWER_PRICE_M3 50 Default price for lowering 1 m3 of ground
DEFAULT_GROUND_RAISE_PRICE_M3 50 Default price for raising 1 m3 of ground
DEFAULT_GROUNDPRICE_M2 400 Default price per square meter of ground
DETAILED true High resolution project
EXPORT_CRS EPSG:3857 Default export CRS for Polygon data in Tygron Client
GRID_CELL_SIZE_M 2 Overlay Grid cell size in meters
IMPORT_CRS Default import CRS for Polygon data in Tygron Client
IMPORT_CRS_FORCE_XY true Default import CRS (force XY) for Polygon data in Tygron Client
ITERATIONS 1 Amount of Iterations during a recalculation update. Min Value: 1 and Max Value: 1000
KEEP_ALIVE NEVER Keep Project alive (active) base on this Setting
LIMIT_MAP MULTIPOLYGON EMPTY Limits Project map generation and later calculation to this MultiPolygon
MAP_SIZE_M 0 0 Project map size in X (longitude) and Y (latitude) in meters
MAX_TOTAL_GRIDCELLS 0 Maximum amount of Overlay Grid cells per Project
MEASUREMENT_SYSTEM_TYPE SI Unit system for Measurements
MIN_CELL_M 0 Minimum Overlay Grid cell size in meters
MODEL_STYLE TEXTURED Model (Buildings, bridges, trees, etc.) style used for visualization in Tygron Client
PROJECT_NAME Project Name Project name
RASTERIZATION COMBINED Selected rasterization method to convert Polygon into the Overlay Grid raster
RECALCULATION_REQUIRED false If true, a manual recalculation update is required
RECENT_CRSS EPSG:3857 EPSG:4326 Recently used export CRS values in Tygron Client
REGION NORTHWESTERN_EUROPE Project Region: used to define the default Functions
RESERVED_LAND MULTIPOLYGON EMPTY MultiPolygon for reserved land used in sale transactions
SATELLITE_BRIGHTNESS -1 Compensates for dark satellite backgrounds in Tygron Client visualization
SATELLITE_COLOR RGBA color to use instead of Satellite imagery for visualization in Tygron Client
SATELLITE_FILE_NAME default Name of the satellite background asset files
SCHEDULED_UPDATE Scheduled update Timestamp in milliseconds
SCHEDULED_UPDATE_MAIL Email Address to notify when the Scheduled Update has finished
SCHEDULED_UPDATE_SMS Phone number to notify via SMS when the Scheduled Update has finished
SECTOR_SIZE_M 500 Height sector tile size in meters
SHOW_ACTION_LOG true Show Action Log Panel in Tygron Client
SHOW_BUILDING_AND_MEASURE_POPUP false Show interaction Popup when a Building is placed
SHOW_WATER_POPUP false Show interaction Popup for the water authority when a waterway is placed
SKY_TYPE DEFAULT Sky visualisation type in Tygron Client
SOLAR_PANEL_POSITION 0.0 -0.5 -1.0 Solar Panel positioning used for visualisation in Tygron Client
STATE NOTHING Simulation Timestate
SUN_DATES Project sun dates used for Sun visualisation in Tygron Client
SUPER_USER_MESSAGE Super user message to all clients
SUPPORT PREMIUM License support level
SURROUNDING_MAP_EXTEND_M 0 0 Surrounding map extent for visualization of Satellite and Elevation around the Project map
TIME_ZONE Project TimeZone offset
TIMESTAMP_FORMAT dd/MM HH:mm:ss timestamp format for importing and exporting date/Time values, such as in CSV files
TRAFFIC_VISUAL_MULTIPLIER 4.0 Traffic visualisation multiplier in Tygron Client (not used in calculations)
WATER_HEIGHT -20000.0 Average water elevation reference Point used for visualisation in Tygron Client
WATER_TYPE CANAL Water visualisation type in Tygron Client
WEB_ALLOW_LOGIC_EVENT true Allow logic endpoint execution for Web Viewers
WEB_ALLOW_PARTICIPANT_EVENT true Allow participant endpoint execution for Web Viewers
WEB_ALLOW_QUERIES false
WEB_BASE_MAP SATELLITE Background type used in Web Viewers
WEB_DEFAULT_APP 2d Default Web Viewer type (2D or 3D)
WEB_FRONT_PANEL -1 Open Web Viewers with this Panel ID instead of default map
WEB_MAP_CUSTOM_PANEL -1 Panel ID used to retrieve and replace custom content for the 2D and 3D Viewers
WEB_MODEL_SHADOW true 3D Web Viewer shadow visualization enabled
WEB_MODEL_SPACING 2.0 3D Web Viewer model spacing, distance between e.g. trees
WEB_MODEL_STYLE WHITE Web Viewer Model style (COLORED or WHITE)
WEB_MODEL_TEXTURE MEDIUM 3D Web Viewer Texture quality/size (SMALL, MEDIUM, LARGE)
WIND_DIRECTION 135 Wind direction angle in degrees
WIND_SPEED_M_PER_S 5.0 Wind speed in meters per second
WIZARD_TIME_MINUTES -1 Project map generation Time in minutes
WORLD_REFERENCE_POINT 0 0 World reference Point (upper left corner) used to convert local coordinates to EPSG 3857 world coordinates
