Water balance (Water Overlay)
Revision as of 14:29, 8 July 2026 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → General tab (Right panel) → Show water balance
The simulation tracks initial water, inflows, outflows, and the remaining water in various layers upon completion. The overview of these tallies is known as the water balance, and can be accessed after the calculation has completed. Water is categorized as input (initialization or entry points) and output (final destination or exit paths).
Input Configuration Result Output Configuration Result
Water surface Water area, Surface level prequel Water surface Surface last value
Inundated Inundation area Surface last value Land Surface Surface last value
Rain Rain m, Rain areas Rain Evaporated Evaporation m Evaporated
Building Storage Water storage m2 Building last storage
Sewer Storage Sewer storage Sewer last value
Sewer Out External Sewer pump speed Object flow output
Breach Breach Object flow output Breach Out Breach Object flow output
Inlet Inlet Object flow output Outlet Outlet Object flow output
Bottom in Bottom Pressure and Resistance prequels Ground bottom flow Bottom Out Bottom Pressure and Resistance prequels Ground bottom flow
Saturated Ground Storage Ground water depth m, Water areas, Ground bottom distance m
Groundwater depth or Groundwater datum, Bottom distance prequels
Unsaturated Ground Storage Unsaturated fraction or prequel
Ground last unsaturated storage Unsaturated Ground Storage Ground last unsaturated storage
