Zip Code
Revision as of 12:27, 13 May 2026 by Frank@tygron.nl (talk | contribs)
Neighborhoods, Zones and Plots
Zip Code is an Item that stores the geometry of a postal code zone.
Zip Codes are automatically created when adding a Zipcodes Overlay.
  • Zip Code is a Sourced Item, which means it records which Sources created it and which Sources changed any of its properties.
  • Currently only Dutch PC6 Zipcodes are imported.
  • It is currently not possible to manually add Zip Code items.
API Endpoints
