Api session event editor setting
Revision as of 11:30, 10 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor setting Events.
API Endpoints for Setting editing.
Name Description
add_crs Add Crs
get_epoch_time Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local Time in this Project
get_sun_altitude Get Sun Altitude value for local Time in this Project
get_sun_azimuth Get Sun Azimuth value for local Time in this Project
get_sun_motion Get Sun Motion value for local Time in this Project (The Netherlands only)
remove_crs Remove Crs
set_currency Set Currency
set_decimals Set Decimals
set_default_geoplugin Set Default Geo Plugin
set_export_crs Set Export Crs
set_grid_cell_size Change the project's grid cell size, used by active Overlay.
set_import_crs Set Import Crs
set_limit_map Set Project Map Limit Area
set_panel_availability Set Panel Availability
set_permission_popup_active Set Permission Popup Active
set_rasterization Set Rasterization
set_region Set Region
set_setting Set Project Setting
set_sun_dates Set Sun Dates
set_timestamp_format Set Timetamp Format
set_unit_system_type Set Unit System Type
set_wind_speed Set Wind Speed
wizard_finished Wizard Finished
Deprecated API Endpoints:
Name Description
set_scheduled_update Deprcated: replaced by editorevent/set_scheduled_update/. Schedule a long-running Update.
