Api session event editor setting
Revision as of 14:16, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API api session event editor setting Events.
Setting editing.
Name Description
ADD_CRS Add Crs
GET_EPOCH_TIME Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local Time in this Project
GET_SUN_ALTITUDE Get Sun Altitude value for local Time in this Project
GET_SUN_AZIMUTH Get Sun Azimuth value for local Time in this Project
GET_SUN_MOTION Get Sun Motion value for local Time in this Project (The Netherlands only)
REMOVE_CRS Remove Crs
SET_CURRENCY Set Currency
SET_DECIMALS Set Decimals
SET_DEFAULT_GEOPLUGIN Set Default Geo Plugin
SET_EXPORT_CRS Set Export Crs
SET_GRID_CELL_SIZE Change the project's grid cell size, used by active Overlays.
SET_IMPORT_CRS Set Import Crs
SET_LIMIT_MAP Set Project Map Limit Area
SET_PANEL_AVAILABILITY Set Panel Availability
SET_PERMISSION_POPUP_ACTIVE Set Permission Popup Active
SET_RASTERIZATION Set Rasterization
SET_REGION Set Region
SET_SETTING Set Project Setting
SET_SUN_DATES Set Sun Dates
SET_TIMESTAMP_FORMAT Set Timestamp Format
SET_UNIT_SYSTEM_TYPE Set Unit System Type
SET_WIND_SPEED Set Wind Speed
WIZARD_FINISHED Wizard Finished
Deprecated Events:
Name Description
SET_SCHEDULED_UPDATE Deprcated: replaced by editorevent/set_scheduled_update/. Schedule a long-running Update.
