Hydrological attributes of terrains (Water Overlay)
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a building is present with overwriting values.
| Icon | Attribute | Unit | Layer | Range | Description |
HYDRAULIC_CONDUCTIVITY_MD | m/day | Ground | Hydraulic conductivity (K) is a measure of the ease with which water can move through pore spaces or fractures in a saturated medium. | |
HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD | m2/day | Ground | This attribute represents the horizontal hydraulic conductivity (KD) of the saturated layer multiplied by the layer thickness. | |
GROUND_INFILTRATION_MD | m/day | Surface | 0.0 to 10.0 | The speed at which water can flow vertically from the surface to the unsaturated zone. |
GROUND_INFILTRATION_MD | m/day | Ground | 0.0 to 10.0 | The speed at which water can flow vertically from the unsaturated zone to the saturated zone. |
ROOT_DEPTH_M | m | Surface | The depth of the roots of the Terrain Type. This depth is used to determine whether evaporation will occur from the groundwater. | |
| WATER | nominal | Surface | Whether this Terrain Type represents a form of water (and what type). | ||
WATER_TRANSPIRATION_FACTOR | factor | Surface | How fast this terrain can evaporate water from the ground. The weather's evaporation speed is multiplied by this factor to determine the rate of transpiration. | |
WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the terrain, which is a measure of surface roughness. Used in the surface flow computation of the Water Overlay. | |
WATER_MICRORELIEF_M | m | Surface | 0 - 0.255 | The defined Microrelief in meters, which captures surface water. When captured, surface flow is halted until the defined threshold is reached. Evaporation and infiltration for water captured in Microrelief is still allowed. |
WATER_STORAGE_PERCENTAGE | fraction (m3/m3) | Ground | The percentage (as a fraction) of the ground layer volume which can be filled with water. A lower percentage means the ground layer will be able to store less water, and the saturated zone will rise higher with the same amount of water in the ground layer. |
- In general, surface Terrain Attributes can be overridden by attributes of buildings on the surface, even when the attribute values of the building are set to 0.
