Function Override
Revision as of 14:29, 1 February 2024 by Frank@tygron.nl (talk | contribs)
This article is a stub.
Function Overrides in relation to Functions.
Function Override is an item that stores changes made to properties of a Function.
When an attribute, function value or other property of a Function is requested, the Function always checks if a Function Override of that function exists and if it overrides that property. In such cases, the property of the Function Override is returned. This system also allows to reset overridden properties back to the original values of the Function, by simply deleting the property in the Function Override.
A Function Override is created once a change has been made to a Function in the editor. This Function Override will have the same ID as the Function.
Function Override of Modern Apartments with a large unit size and an alternative name, as shown in the API
