Shoreline (Water Overlay)
Revision as of 10:29, 29 January 2024 by Frank@tygron.nl (talk | contribs)
Icon | Attribute | Unit | Range | Description | Default value |
SHORELINE | boolean | Whether to automatically fill cells near a water terrain when there is a mismatch between the extend of the water terrain and the DEM. | True |
When a Waterway polygon is not correctly positioned in relation to the DEM this can result in filling up the nearby land with water at the start of the simulation. This will result in a lower water level then is expected from the water area value. To correct this, a "shoreline" is added at neighbouring cells. At the start of the simulation, these shoreline cells will also be filled with water up to the nearby water level to prevent the initial flush.
Difference in water level.
- This option is active by default.
- Shoreline currently only extends to one grid cell in each direction.
