Water balance (Water Overlay)
| Input | Configuration | Result | Output | Configuration | Result |
| Water surface | Water area, Surface level prequel | Water surface | Surface last value | ||
| Inundated | Inundation area | Surface last value | Land Surface | Surface last value | |
| Rain | Rain m, Rain areas | Rain | Evaporated | Evaporation m | Evaporated |
| Building Storage | Water storage m2 | Building last storage | |||
| Sewer Storage | Sewer storage | Sewer last value | |||
| Sewer Out External | Sewer pump speed | Object flow output | |||
| Breach | Breach | Object flow output | Breach Out | Breach | Object flow output |
| Inlet | Inlet | Object flow output | Outlet | Outlet | Object flow output |
| Bottom in | Bottom Pressure and Resistance prequels | Ground bottom flow | Bottom Out | Bottom Pressure and Resistance prequels | Ground bottom flow |
| Saturated Ground Storage | Groundwater depth or Groundwater datum, Bottom distance prequels | Saturated Ground Storage | |||
| Unsaturated Ground Storage | Unsaturated fraction, prequel | Ground last unsaturated storage | Unsaturated Ground Storage | Ground last unsaturated storage |
