Measure
A measure can be used to:
- Placing Buildings. These buildings will be linked to the measure;
- Execute terrain adjustments. Stored in measure as MeasureSpatials;
- Applying changes in elevation using GeoTIFFs. Stored in measure as TiffSpatials;
- Upgrade existing Buildings that overlap the defined upgrade selection; Stored in measure as UpgradeSpatials;
- Placing Levees with side and top functions; Stored in measure as LeveeSpatials;
- Execute Server events. Stored in measure with two lists: one for when measure is constructed and one for when measure is cancelled.
When to use measures
(In Dutch)
Creating and editing measures
- How to add and remove measures
- How to edit general measure properties
- How to edit measure cost details
- How to edit measure events
- How to edit spatial components of a measure
- How to add a GeoTIFF to a measure
Advanced usage of measures
Not showing spatial effects
Reusing measures
Using the above principle, it is also possible to reuse measure. If multiple measures would have the same spatial effect, it is possible to have an additional measure in which the actual spatial effect is defined. All measures which should have that spatial effect can trigger the additional measure. This has the benefit of being easier to maintain if the spatial effect needs to change. Any change to the plan would only require a change to a single measure, instead of all measures which have the same effect.
File:QA verschil terrains buildings measures wiki.jpg
(In Dutch)
