Current Situation
Revision as of 14:29, 7 October 2022 by Frank@tygron.nl (talk | contribs)
The Current situation tab is the first of the four ribbon tabs and is located in the top part of the editor. The Current situation tab contains tools which relate to the editing, configuring and building of the current situation in the project. The current situation is the starting setting for a project before any planning or analysis is to be performed.
The editor. The Current situation tab is located in the ribbon bar at the top of the editor.
The Current situation tab consists of the following tool options:
Buildings, Functions, Addressess, Plots, Unit Types, Unit Type Overrides
Net Nodes, Net Lines, Net Loads, Net Clusters, Net Settings, Net Functions
Neighborhoods, Areas, Zones, Zip Codes, Plots
Terrains, Terrain Types, Terrain Type Overrides, Height Sectors, Geo Tiffs
