Tracer ABCD (Water Overlay)
Revision as of 11:16, 5 October 2022 by Maxim@tygron.com (talk | contribs)
Buildings with a positive TRACER Attribute are known as chemical emitters. Buildings with a negatice TRACER Attribute are known as chemical decomposers.
Chemical emitters are Buildings which produce specific chemicals. The net amount of chemicals a single Building creates is spread out across it's surface. After the chemicals are created, any water flowing through the same location will carry a part of the chemicals with it.
Structures which are defined to create a negative amount of chemicals function as a scrubber or decomposer, removing the specified quantity of chemicals from the hydrological model.
In situations where water is absent, chemicals will not be moved between cells.
  • Chemical emitters must be Buildings on the surface, not underground Buildings.
  • Chemical emitters's attributes do not take the form of function values, and thus must be added manually or as part of loading in geodata.
  • Chemicals have generic definitions, in terms of name and magnitude, to allow for the modeling of arbitrary tracers.
