Max infiltration m (Water Overlay)
Revision as of 16:14, 9 February 2022 by Frank@tygron.nl (talk | contribs)
Icon | Attribute | Unit | Range | Description | Default value |
INFIL_ONLY_BOTTOM_DISTANCE_M | m | Assumed maximum amount of infiltrated water that can be stored underground. | n/a |
- Contrary to the title of the model attribute, it is actually a storage amount. The distance is misleading, since it does not interact with the local storage capacity of the underground.
- This option is only relevant when the In case the ground water mode is set to Infiltration only. In case the ground water mode is set to Complete, this model attribute is ignored.
