Hydrological attributes of terrains (Water Overlay)
Revision as of 07:30, 3 September 2020 by Rudolf@tygron.nl (talk | contribs)
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a construction is present with overwriting values.
  • In general, surface terrain attributes can be overridden by attributes of constructions on the surface, even when the attribute values of the construction are set to 0.
