Terrain ground infiltration md (Water Overlay)
Template:Overlay attribute
Infiltration and storage
The maximum amount of water which can be stored in the saturated zone is based on the water storage percentage.
Underground flow, or horizontal infiltration, are dependent on the infiltration properties of the underground, unless an aquifer exists at the same location.
  • The groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE, as the contribution of a given volume of water to the groundwater level increases when the capacity for water storage in the underground layer decreases.
