Terrain ground infiltration md (Water Overlay)
Revision as of 08:30, 9 May 2019 by Frank@tygron.nl (talk | contribs) (Frank@tygron.nl moved page Terrain Ground infiltration md (Water Overlay) to Terrain ground infiltration md (Water Overlay) without leaving a redirect)
Infiltration and storage
Underground flow, or horizontal infiltration, are dependent on the infiltration properties of the underground, unless an aquifer exists at the same location.
- The groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE, as the contribution of a given volume of water to the groundwater level increases when the capacity for water storage in the underground layer decreases.
