Model attributes (Water Overlay)
The water overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the water overlay and can be modified as such.
Icon Attribute Unit Description
GRAVITY m/s² Used constant for gravitational acceleration
LIMIT_RAIN boolean Whether rainfall locations should be limited to water level areas (1) or everywhere (0).
MAX_WATER_DEPTH_M m
QUAD_CELL boolean This attribute name is reserved for future functionality. Currently, this marks an experimental feature which is currently under development and may result in unexpected behavior when activated.
TIMEFRAMES integer The number of intermediate results recorded during the calculation. Each timeframe becomes a snapshot of data which can be viewed and analysed. The total simulation time is divided by this value, and at each interval of that period of time a snapshot of the results so far is made. Note that the first timeframe does not contain the starting conditions of the simulation, but the state of the simulation after the first period of time has passed.
WALL_ANGLE degrees The minimal angle for a slope to be considered a wall. Cells that have a wall behavior will slow down and reflect the water's movement considerably. The x- and y-direction are handled separately.
