Heat Stress Overlay Wizard
(Redirected from Heat Stress Overlay Wizard (Heat Stress Overlay))
How to set up the Heat Stress Overlay Wizard
Generally, the steps required to use and configure the Heat Stress Overlay are as follows:
- Determine the location and area of interest and generate a project for that area;
- Add the Heat Stress Overlay;
- Open the Heat Stress Overlay wizard to kick off the configuration process.
- Select date(s) and time of day
- Supply daily weather station data
- Supply hourly weather station data
- Select source for Foliage height
Date and time of day
- Select a day for which you want to generate results. You can also choose to select multiple consecutive days when using the Heat Stress Overlay Wizard.
- For each day, select the hours for which you want to generate results. Each day-hour combination will become a result. This result is stored as a time-frame to relate it back to the day and time.
Generated sun parameters
- The wizard uses the date, time, and project location to calculate sun altitude and azimuth angles.
- The sun daily motion factor is a parameter used in the atmospheric temperature formula. It will be automatically selected from the sun motion table, based on the sunrise/sunset period for that date (column) and the hour (row).
Weather station data
Next, manually determine which weather station you want to use as a reference. Download the historical hourly weather data for that station and use the data from certain columns as input. In a nutshell, using the weather data, you have to supply:
- Daily Values
- The minimum and maximum temperature of the day;
- The average wind speed, measured at the height of 10 meters;
- The average global sun radiation during sun hours;
- Hourly Values
- The hourly humidity;
- The hourly sun radiation, as an average of the current and previous hour;
- The hourly temperature;
- The hourly wind speed;
- The hourly wind direction;
More information on importing weather data:
- How to import KNMI weather data into Microsoft Excel
- How to calculate the hourly humidity
- How to calculate the hourly radiation
- How to calculate the hourly wind speed
- How to calculate the hourly wind direction
- How to calculate the daily min and max temperature
- How to calculate the daily average radiation
- How to calculate the daily average wind speed
Foliage Height
Select what source will define the Foliage height:
- Buildings with functions related to foliage. The foliage height calculation model will determine the foliage height using the height of the vegetation (as buildings) and the foliage crown factor attribute;
- Areas with a foliage height attribute, defining the foliage height for a whole area;
- GeoTIFF, defining a foliage height value for each cell in its raster.
More information on how to define Foliage height:
- How to adjust the foliage height and crown factor
- How to import foliage height areas
- How to import a foliage height GeoTIFF
Further reading
To read more documentation about the Heat Stress Overlay go to DPRA Heat Stress Module
