Heat Stress Overlay Wizard
How to set up the Heat Stress Overlay Wizard
Generally, the steps required to use and configure the Heat Stress Overlay are as follows:
- Determine the location and area of interest and generate a project for that area;
- Add the Heat Stress Overlay;
- Open the Heat Stress Overlay wizard to kick off the configuration process.
- Select date(s) and time of day
- Supply daily weather station data
- Supply hourly weather station data
- Select source for Foliage height
Date and time of day
- Select a day for which you want to generate results. You can also choose to select multiple consecutive days when using the Heat Stress Overlay Wizard.
- For each day, select the hours for which you want to generate results. Each day-hour combination will become a result. This result is stored as a time-frame to relate it back to the day and time.
Generated sun parameters
- The wizard uses the date, time, and project location to calculate sun altitude and azimuth angles.
- The sun daily motion factor is a parameter used in the atmospheric temperature formula. It will be automatically selected from the sun motion table, based on the sunrise/sunset period for that date (column) and the hour (row).
Weather station data
Next, manually determine which weather station you want to use as a reference. Download the historical hourly weather data for that station and use the data from certain columns as input. In a nutshell, using the weather data, you have to supply:
- Daily Values
- The minimum and maximum temperature of the day;
- The average wind speed, measured at the height of 10 meters;
- The average global sun radiation during sun hours;
- Hourly Values
- The hourly humidity;
- The hourly sun radiation, as an average of the current and previous hour;
- The hourly temperature;
- The hourly wind speed;
- The hourly wind direction;
More information on importing weather data:
- How to import KNMI weather data into Microsoft Excel
- How to calculate the hourly humidity
- How to calculate the hourly radiation
- How to calculate the hourly wind speed
- How to calculate the hourly wind direction
- How to calculate the daily min and max temperature
- How to calculate the daily average radiation
- How to calculate the daily average wind speed
Foliage Height
Select what source will define the Foliage height:
- Buildings with functions related to foliage. The foliage height calculation model will determine the foliage height using the height of the vegetation (as buildings) and the foliage crown factor attribute;
- Areas with a foliage height attribute, defining the foliage height for a whole area;
- GeoTIFF, defining a foliage height value for each cell in its raster.
More information on how to define Foliage height:
- How to adjust the foliage height and crown factor
- How to import foliage height areas
- How to import a foliage height GeoTIFF
Further reading
To read more documentation about the Heat Stress Overlay go to DPRA Heat Stress Module
