How to adjust the foliage height and crown factor
How to adjust the foliage height and crown factor:
  1. Add the Heat Stress Overlay
  2. Open the Configuration Wizard
  3. Choose the DPRA model
  4. In step 3.1, select the first option: 'use tree functions height and foliage crown factor'.
  5. Click in the next step on the Adjust Function Values button
  6. In the Function values table that pops up, set the category filter on Nature and the group filter on Environment to see the tree functions.
  7. Double-click the Foliage crown factor value, enter the new amount, and press Enter.
  8. Set the group filter on Construction and change the Floor height m attribute to the desired value.
  9. When the values are adjusted, close the Function values table and proceed with the Heat wizard.
