Dates (Heat Stress Overlay)
| DATES | time in milliseconds | : Dates specify the timeframes (day and time) used to calculate sun angles. | 1375444800000 |
- It is recommended to use the Heat Stress Overlay Wizard to generate and edit the dates.
- The sun altitude and sun azimuth are automatically recalculated based on project location and date only when using the Heat Stress Overlay configuration wizard, not when modifying the attribute directly.
- The dates are stored as milliseconds past the defined epoch. Care should be taken when manually adjusting these numbers!
API Endpoints
