Api event share
API Endpoint: api/event/share/
Endpoints related to the GeoShare.
Name Description
add Add new Shareable for given path, name and type; returns a unique path with primary extension. For files larger than 2GB, use the Stream API.
add_url Add new Shareable for given path, name and type; returns a unique path with primary extension.
get_shareables Get all shareables in the given path. Tokenized shareables are included only for accounts with EDITOR level or higher.
get_viewer_input Get viewer content array for given path.
move Move the Shareable to a new path.
remove Remove Shareable for given paths.
set_certificate_author Set Certificate of Authorship to validate the originality of the shareable in a Project.
set_description Set description for given path.
set_disclaimer Set disclaimer for given path.
set_icon Set icon for given path.
set_token Set token for given path.
set_viewer_input Set viewer content array for given path.
update Update Shareable content.
