Api event share update
API Endpoint: api/event/share/update/
Description: Update Shareable content.
0 REQUIRED (String) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (byte or multiple values in array [a, b, c]) Content Bytes
200 String (String)
curl 'https://devshare.tygron.com/api/event/share/update/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path", 1 ]'
Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/update/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path", [ 1, 2, 3 ] ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Path", 1 ]'
fetch("https://devshare.tygron.com/api/event/share/update/", options)
