Api event share add
API Endpoint: api/event/share/add/
Description: Add new Shareable for given path, name and type; returns a unique path with primary extension. For files larger than 2GB, use the Stream API.
0 REQUIRED (String) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (Enumeration) Type CITYGML, CITYJSON, CSV, DIRECTORY, DOC, DXF, EXCEL, GEOJSON, GEOPACKAGE, GEOTIFF, GIF, IFC, JPEG, MARKDOWN, ONNX, PDF, PNG, SLIDES, SLPK, TXT, VIEWER or ZIP
2 OPTIONAL (byte or multiple values in array [a, b, c]) Content Bytes (< 2GB) (optional)
200 String (String)
curl 'https://devshare.tygron.com/api/event/share/add/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path", "GEOTIFF" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Path", "GEOTIFF" ]'
fetch("https://devshare.tygron.com/api/event/share/add/", options)
