Api event share get viewer input
API Endpoint: api/event/share/get_viewer_input/
Description: Get viewer content array for given path.
0 REQUIRED (String) Path (note: viewers end with a slash e.g. "mydir/viewer/")
200 String[] (Array of viewer input shareables.)
curl 'https://devshare.tygron.com/api/event/share/get_viewer_input/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Path"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '"Path"'
fetch("https://devshare.tygron.com/api/event/share/get_viewer_input/", options)
