Api event share set icon
API Endpoint: api/event/share/set_icon/
Description: Set icon for given path.
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Icon Name
200 Boolean (Content was updated)
curl 'https://devshare.tygron.com/api/event/share/set_icon/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path 1", "Icon Name 1" ]'
Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/set_icon/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ [ "Path 1", "Path 2", "Path 3" ], [ "Icon Name 1", "Icon Name 2", "Icon Name 3" ] ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Path 1", "Icon Name 1" ]'
fetch("https://devshare.tygron.com/api/event/share/set_icon/", options)
