Api event share move
API Endpoint: api/event/share/move/
Description: Move the Shareable to a new path.
0 REQUIRED (String) Old Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (String) New Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
200 String (String)
curl 'https://devshare.tygron.com/api/event/share/move/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Old Path", "New Path" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Old Path", "New Path" ]'
fetch("https://devshare.tygron.com/api/event/share/move/", options)
