Api event share get shareables
API Endpoint: api/event/share/get_shareables/
Description: Get all shareables in the given path. Tokenized shareables are included only for accounts with EDITOR level or higher.
| 0 | REQUIRED | (String) | Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/") | |
| 1 | OPTIONAL | (Type or multiple values in array [a, b, c]) | Types (optional) |
| 200 | Shareable[] (Shareable array) |
curl 'https://devshare.tygron.com/api/event/share/get_shareables/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Path"'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '"Path"'
fetch("https://devshare.tygron.com/api/event/share/get_shareables/", options)
