Api event share remove
API Endpoint: api/event/share/remove/
Description: Remove Shareable for given paths.
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/") |
| 200 | Boolean (True when at least one item was removed) |
curl 'https://devshare.tygron.com/api/event/share/remove/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Path 1"'Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/remove/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path 1", "Path 2", "Path 3" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '"Path 1"'
fetch("https://devshare.tygron.com/api/event/share/remove/", options)
