Api event share
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "<noinclude lang="text" copy>API Endpoint: api/event/share/ </noinclude><noinclude lang="text" copy> Endpoints related to the GeoShare. </noinclude>{|class=wikitable !Name !Description |- | add | Add new Shareable for given path, name and type; returns a unique path with primary extension. For files larger than 2GB, use the Stream API. |- | add_url | Add new Shareable for given path, name and type; returns a unique path...")
Name Description
add Add new Shareable for given path, name and type; returns a unique path with primary extension. For files larger than 2GB, use the Stream API.
add_url Add new Shareable for given path, name and type; returns a unique path with primary extension.
get_shareables Get all shareables in the given path. Tokenized shareables are included only for accounts with EDITOR level or higher.
get_viewer_input Get viewer content array for given path.
move Move the Shareable to a new path.
remove Remove Shareable for given paths.
set_certificate_author Set Certificate of Authorship to validate the originality of the shareable in a Project.
set_description Set description for given path.
set_disclaimer Set disclaimer for given path.
set_icon Set icon for given path.
set_token Set token for given path.
set_viewer_input Set viewer content array for given path.
update Update Shareable content.
