How to create an SLPK file
Revision as of 09:53, 18 November 2026 by Server@tygron.com (talk | contribs)
This page provides information on how to export a SLPK file with ArcGIS Pro. The ArcGIS Pro version used in this documentation is 2.4.0.
To learn more about ArcGIS Pro visit ESRI's ArcGis Pro Documentation. In order to export a 3D model as a SLPK, it has to be imported into ArcGIS Pro and Georeferenced to place the model on the right location.
ArcGIS Pro allows different file formats to be imported.
Requirements on 3D model data
Below some notes to take into account when importing a 3D model into the Tygron Platform
  • If the 3D model is of a 3D plan with multiple Functions, take note of the following. For each Function in the 3D plan, a separate SLPK file should be created, since it is not possible to do a function mapping when importing. Therefore, you could also consider to only transform the 3D buildings into a SLPK file to import these models as one function into the Tygron Platform. If there are multiple types of buildings in the plan, then create multiple SLPK files or after importing, change the type of buildings manually in the Platform. The other elements in the plan, such as roads, squares and green spaces can be transformed to a (2D) GeoJSON file. For a GeoJSON it is possible to do a function mapping when importing, only then the generic Tygron models are used for the elements in the plan.
  • The 3D plan should only contain the new functions (the new adjustments to the current situation) and no existing functions such as the surroundings.
  • If possible, try to draw the model directly on the right location or after finishing the model, move it to the right location. This saves a few steps in preparing the data before importing in the Tygron Platform.
  • When drawing the 3D plan, work with different layers for the different Functions in the design. For example, all office buildings are in a layer called offices, parks are in the layer green spaces etc. Try to be clear with the naming of the layers.
  • Be aware of the fact that Functions in the Tygron Platform can't overlap. For example a building polygon may not be on top of a green space polygon. In the Tygron Platform this would translate to either the building which is imported or the green space, since it is not possible to stack functions on top of each other. In this case, the green space should be drawn surrounding the building polygon.
  • Try to make the model as neat as possible to ensure a valid data file. For example, no lines or polygons on top of each other (duplicates), loose line segments or surfaces that do not belong to the plan, polygons that are not closed etc.
1. Creating a new ArcGIS Pro project
First create a new project in ArcGIS Pro. When starting a new project make sure that you select a local Scene from the Blank Templates section. You can convert a local scene to a global scene after you have imported your model(s).
2. Adding 3D data files
It is also possible to import BIM data in ArcGIS Pro. However we recommend doing this via IFC directly.
3. Export the model as a SLPK file
After importing and if needed Georeferencing your model you can export the model to a SLPK file by following the steps below, which are divided into three sections. Please follow them in order.
How to create a Feature Class:
  1. In ArcGIS Pro go to the "Analysis" Tab and select "Tools".
  2. On the right pane navigate to the "Feature Class to Feature Class" tool or type it in the search bar to find it.
  3. In the "Input Features" field select the Multipatch feature(s) of the imported object by clicking on the dropdown in the field to select the layers.
  4. The Output location will be a .gdb (database file) with the project as a name. Leave the default name as is or rename it if you prefer.
  5. In the "Output Feature Class" field type in a name.This will save the Multipatch layer(s) to the database.
  6. Click on the Environments tab and choose the CRS for your data.
  7. Click on "Run" at the bottom right of the pane.
Note: these steps can be skipped when converting from a DWG file. Continue directly to the steps for exporting an SLPK instead.
How to create a Layer 3D:
  1. Go to the "Analysis" Tab and select "Tools" again.
  2. On the right pane navigate to the "Layer 3D to Feature Class" tool or type it in the search bar to find it.
  3. In the "Input Feature Layer" field select the newly created feature class not the original multipatch layer(s).
  4. An automatic name will be generated in the "Output Feature Class" field. Usually it will append a "_Layer3DToF1" tag after the Multipatch name. Leave as default or rename it if you want. Make sure that you can identify the name because we will be needing it in the final step.
  5. Check "Disable Color and Texture" only if you do not want these features to be converted.
  6. Click on "Run" at the bottom right of the pane.
How to Export to SLPK:
  1. Finally go to the "Analysis" Tab and select "Tools" again.
  2. On the right pane navigate to the "Create 3D Object Scene Layer Package" tool or type it in the search bar to find it.
  3. In the "Input Dataset" field select the created Layer3d file from the previous steps.
  4. In the "Output Scene Layer Package" field type in the name for the SLPK file wich will be created and choose the location for the file to be saved.
  5. Optimize the textures for various platform by choosing an option from the "Texture Optimization" dropdown field or leave at the default setting.
  7. Now a SLPK file will be created.
  • It is no longer required to Geo-position the SLPK. A button named 'Reposition Model' has been added to the Model Placement step of the Geo Import Wizard that allows you to reposition the 3D models in the project area.
