Api session event editor building
Revision as of 10:22, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/
API Endpoints for Building editing.
Name Description
add Add a new Building, owned by a Stakeholder, with a provided Function and name
add_polygons Add Polygons for Building Section. If the Building is empty, optionally set ownership to the largest Plot Owner of the provided MultiPolygon
append_attribute Appended to existing Building numeric Attribute value
duplicate Duplicate existing Building
import Import Building Collection
remove Remove existing Building
remove_attribute Remove numeric Attribute from Building
remove_polygons Remove Polygons from a Building Section
set_attribute Set Building numeric Attribute value
set_attributes Set multiple Building numeric Attribute values
set_name Set the name of a Building
Additional API Endpoints:
Name Description
add_geometry Add a Custom Geometry to a Building
add_road Add a new Building, owned by a Stakeholder, with a default road Function
add_section Add a new Section to a Building
add_standard Add a new Building, owned by a Stakeholder, with a default housing Function
add_underground Add a new Building, owned by a Stakeholder, with a default underground Function
duplicate_section Duplicate a Building Section
generate_rotation_angles Calculate a rotation angle for Buildings with Polygons for the identifying Attribute, optionally only for specified Buildings
generate_water_connection Generate Water Connections, with a Function, within a provided MultiPolygon. Connections are only taken into account when within the provided parameter bounds
multi_select Change the Function of multiple Buildings. Optionally adjust the floors (>0). Optionally merge the Buildings into one
query Execute a single TQL Query. Use the Session/query Endpoint for multiple statements or detailed API usage information
remove_geometries Remove all Custom Geometries from a Building
remove_sections Remove a Section from a Building
reset_category_values Reset values of Category Values of a Building for a Category
reset_function_values Reset the values of Function Values for a Building
reset_slanting_roof_height Reset Height of the Slanting Roof of a Building Section
set_category_value Set the values of a Category Value for a Building and a Category
set_decals Set the decal values (door, window etc) for a Face Type of a Building
set_floors Set the number of floors of a Building's Section
set_function Set the Function of a Building
set_function_value Set the values of a Function Value for a Building
set_owner Set the owner of a Building
set_slanting_roof_height Change Height of the Slanting Roof of a Section of a Building
