Api session event editor building reset function values
API Endpoint: api/session/event/editorbuilding/reset_function_values/
Description: Reset the values of Function Values for a Building
0 REQUIRED (BUILDING Integer ID) Building
1 REQUIRED (FunctionValue or multiple values in array [a, b, c]) Function Values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "LIVABILITY_EFFECT" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "LIVABILITY_EFFECT", "CRITICAL_INFRASTRUCTURE", "NUM_CARS" ] ]'
JavaScript example POST
 body: '[ 1, "LIVABILITY_EFFECT" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/reset_function_values/", options)
