Api session event editor building reset slanting roof height
API Endpoint: api/session/event/editorbuilding/reset_slanting_roof_height/
Description: Reset Height of the Slanting Roof of a Building Section
| 0 | REQUIRED | (BUILDING Integer ID) | Building | |
| 1 | REQUIRED | (Integer number) | Section ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/reset_slanting_roof_height/", options)
