Api session event editor building set category value
API Endpoint: api/session/event/editorbuilding/set_category_value/
Description: Set the values of a Category Value for a Building and a Category
| 0 | REQUIRED | (BUILDING Integer ID) | Building | |
| 1 | REQUIRED | (Enumeration) | Category | AGRICULTURE, BRIDGE, EDUCATION, GARDEN, HEALTHCARE, INDUSTRY, INTERSECTION, LEISURE, LUXE, NATURE, NORMAL, OFFICES, OTHER, PARK, PAVED_AREA, ROAD, SENIOR, SHOPPING, SOCIAL, STUDENT or UNDERGROUND |
| 2 | REQUIRED | (Enumeration) | Category Value | BUYOUT_COST_M2, CATEGORY_WEIGHT, CONSTRUCTION_COST_M2, DEMOLISH_COST_M2, HEAT_FLOW_M2_CHANGE_PER_YEAR, HEAT_FLOW_M2_START_VALUE, HEAT_FLOW_M2_START_YEAR, HEAT_POWER_TO_FLOW_MULTIPLIER, PARKING_LOTS_DEMAND_PER_M2, PARKING_LOTS_PER_M2, SELL_PRICE_M2 or UNIT_SIZE_M2 |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Values |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_category_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL", "CATEGORY_WEIGHT", 1.0 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_category_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL", "CATEGORY_WEIGHT", [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST
body: '[ 1, "SOCIAL", "CATEGORY_WEIGHT", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_category_value/", options)
