Api session event editor building reset category values
API Endpoint: api/session/event/editorbuilding/reset_category_values/
Description: Reset values of Category Values of a Building for a Category
| 0 | REQUIRED | (BUILDING Integer ID) | Building | |
| 1 | REQUIRED | (Enumeration) | Category | AGRICULTURE, BRIDGE, EDUCATION, GARDEN, HEALTHCARE, INDUSTRY, INTERSECTION, LEISURE, LUXE, NATURE, NORMAL, OFFICES, OTHER, PARK, PAVED_AREA, ROAD, SENIOR, SHOPPING, SOCIAL, STUDENT or UNDERGROUND |
| 2 | REQUIRED | (CategoryValue or multiple values in array [a, b, c]) | Category Values |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_category_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL", "CATEGORY_WEIGHT" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/reset_category_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL", [ "CATEGORY_WEIGHT", "UNIT_SIZE_M2", "HEAT_FLOW_M2_START_VALUE" ] ]'JavaScript example POST
body: '[ 1, "SOCIAL", "CATEGORY_WEIGHT" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/reset_category_values/", options)
