Api session event editor building add underground
API Endpoint: api/session/event/editorbuilding/add_underground/
Description: Add a new Building, owned by a Stakeholder, with a default underground Function
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
200 Integer (Building ID)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_underground/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_underground/", options)
