Api session event editor building generate water connection
API Endpoint: api/session/event/editorbuilding/generate_water_connection/
Description: Generate Water Connections, with a Function, within a provided MultiPolygon. Connections are only taken into account when within the provided parameter bounds
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
2 REQUIRED (Floating point number) Min Length
3 REQUIRED (Floating point number) Max Length
4 REQUIRED (Floating point number) Width
5 REQUIRED (Floating point number) Large Road Area
6 REQUIRED (Floating point number) Straight Distance
7 REQUIRED (Floating point number) Max Height Difference
8 REQUIRED (Floating point number) Ignore Upstream
9 REQUIRED (true, false) Include Water Bodies true or false
200 Integer (Number of generated objects)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 5, 42, 96, 5, 88, 99, 48, true ]
Curl example multi item POST
[ 1, {
}, 14, 64, 99, 67, 95, 87, 7, true ]
JavaScript example POST
 body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 5, 42, 96, 5, 88, 99, 48, true ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857", options)
