Api session event editor building
API Endpoint: api/session/event/editorbuilding/
API Endpoints for Building editing.
| Name | Description |
| add | Add a new Building, owned by a Stakeholder, with a provided Function and name. |
| add_polygons | Add Polygons for Building Section. If the Building is empty, optionally set ownership to the largest Plot Owner of the provided MultiPolygon |
| append_attribute | Appended to existing Building numeric Attribute value |
| duplicate | Duplicate existing Building |
| import | Import Building Collection |
| remove | Remove existing Building |
| remove_attribute | Remove numeric Attribute from Building |
| remove_polygons | Remove Polygons from a Building Section |
| set_attribute | Set Building numeric Attribute value |
| set_attributes | Set multiple Building numeric Attribute values |
| set_name | Set the name of a Building. |
Additional API Endpoints:
| add_geometry | Add a Custom Geometry to a Building |
| add_road | Add a new Building, owned by a Stakeholder, with a default road Function |
| add_section | Add a new Section to a Building. |
| add_standard | Add a new Building, owned by a Stakeholder, with a default housing Function |
| add_underground | Add a new Building, owned by a Stakeholder, with a default underground Function |
| duplicate_section | Duplicate a Building Section. |
| generate_rotation_angles | Calculate a rotation angle for Buildings with Polygons for the identifying Attribute, optionally only for specified Buildings. |
| generate_water_connection | Generate Water Connections, with a Function, within a provided MultiPolygon. Connections are only taken into account when within the provided parameter bounds. |
| multi_select | Change the Function of multiple Buildings. Optionally adjust the floors (>0). Optionally merge the Buildings into one. |
| query | Execute a single TQL Query. Use the [[Session/query Endpoint]] for multiple statements or detailed API usage information. |
| remove_geometries | Remove all Custom Geometries from a Building |
| remove_sections | Remove a Section from a Building. |
| reset_category_values | Reset values of Category Values of a Building for a Category. |
| reset_function_values | Reset the values of Function Values for a Building. |
| reset_slanting_roof_height | Reset Height of the Slanting Roof of a Building Section |
| set_category_value | Set the values of a Category Value for a Building and a Category. |
| set_decals | Set the decal values (door, window etc) for a Face Type of a Building. |
| set_floors | Set the number of floors of a Building's Section |
| set_function | Set the Function of a Building. |
| set_function_value | Set the values of a Function Value for a Building. |
| set_owner | Set the owner of a Building. |
| set_slanting_roof_height | Change Height of the Slanting Roof of a Section of a Building |
