WMS
Revision as of 08:29, 9 October 2026 by Frank@tygron.nl (talk | contribs)
Accessing the WMS Endpoint
A Web Map Service, in short WMS, is an OGC standard which publishes geospatial image data. A WMS often serves its data in multiple layers. A WMS layer generally consists of map images and does not serve features or attributes directly. One of the advantages of a WMS is that the data is accessible on the internet and that the images are always tied to a geographical location.
The data from the WMS can also be imported into the Tygron Platform as a WMS Overlay.
Tygron Platform as a WMS to view Overlays in other software
The Tygron Platform can also act as a WMS to serve Overlays of a running project. The data, along with the same legend and colors can then be viewed in other software, such as a GIS. Also, the WMS supports GetFeatureInfo requests to get data of a particular coordinate of the map. To obtain the WMS URL for use in other software, go to the Tools menu and hover over Web interface.
Editor → Tools (Ribbon tab) → API Overview (Ribbon bar) → Show WMS url (Dropdown)
You will be redirected to a webpage in a browser. Copy the URL of the webpage; this is the WMS URL that can be used in a GIS. For more technical details, see Web wms.
Project Background Layers
The following background layers, not based on an Overlay, are also supported:
  • SATELLITE
  • TOPOGRAPHIC
  • GRAY
These can be found at the bottom of the defined layers on the WMS capabilities page.
  • Notice that the URL contains a token. This token is unique for the (editor) session. Read more about tokens on this page.
Every time you open a project in the editor or start a new session, a new token is generated. Closing the project invalidates the current WMS URL; a new one must be obtained for each new editor session.
When the project is on Keep alive, the WMS URL will stay the same. To set the project on Keep alive, go to the File tab in the Editor and check the box Keep editor session alive. Save the project. The project is then active and can be found in the Join menu.
Read the following pages for more information on how to add your project's WMS in different GIS:
API Endpoints
