Api session event editor area
Revision as of 15:22, 30 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/
API Endpoints for Area editing.
Name Description
add Add new Area
add_polygons Add Polygons to existing Area
append_attribute Appended to existing Area numeric Attribute value
duplicate Duplicate existing Area
import Import Area Collection
remove Remove existing Area
remove_attribute Remove numeric Attribute from Area
remove_polygons Remove Polygons from existing Area
set_active Set Area active
set_attribute Set Area numeric Attribute value
set_attributes Set multiple Area numeric Attribute values
set_color Set new color of existing Area
set_name Set new name of existing Area
set_polygons Set Polygons to existing Area
Additional API Endpoints:
Name Description
add_group Add Group
add_relation Add Relation
add_with_attribute Add With Attribute
generate_border_areas Generate Border Areas
generate_inundation_areas Generate Inundation Areas
generate_sewer_areas Generate Sewer Areas for Neighborhoods
generate_water_areas Generate Water Areas
remove_all_attributes Remove All Attributes
remove_group Remove Group
remove_relations Remove Relations
set_relation Set Relation
